Gear oil plug...!
StrkVRD24
Broward, Florida
Hello Everyone,
New member heređź‘‹. I purchased a new Stark from a local dealer. Went to perform the break-in oil change and after removing the skid plate and taking a peek at the plug.....I saw that it is obviously marred. Apparently, it has been over tightened in the factory. I got my flashlight and glasses because I literally couldn't believe what I was seeing. The torx bit won't even bite with fingertip pressure. I know extraction is my only option. Hoping for the most up-to-date effective/safest extrication method you guys have come up with? Any advice is much appreciated in advance Thank you.
Hello Everyone,
I would send that photo to Stark, they should send you the new redesigned plug with an external hex.
See this thread:
OH, and welcome, this forum is the best place I have found for Stark Varg info.
StrkVRD24
Broward, Florida
See this thread:
See this thread:
Thanks, I had the email and photo sent within 5 minutes of dropping the skid plate. The plug is in route they were quick to respond. I'm just trying to formulate the game plan for the obvious.
That thread is a bit long, but there are photos and advice from folks who had to use a chisel or other extraction methods.
happyinmotion
New Zealand
When mine stripped, I filed the sides of the bolt head to give me two parallel surfaces, then used a spanner to undo it.
If that didn't work, my next plan was to file it into a hex so I could undo it with a six-point socket.
You can cut a slot in the face of the bolt and use a screwdriver or chisel, but applying force to the sides of the bolt head will let you use more force.
Has anyone tried using an EZ Out, if it worked what size?
the size that fits :cool:
Honestly, unless you drill it through first, an ez out is probably not going to work since it looks like they torqued the :poop: out of it.
I would use a hammer and punch, or cut a slot with a cut off wheel.
That other thread has methods from folks who have successfully extracted theirs.
Good luck, and it's great that you already got the correct replacements!
