Generator compatible with Redshift SM?
Salamander
Burns, OR
Out in the desert yesterday I found out the hard way that my uncle’s Westinghouse iGen2200 is not compatible with the SM (error: ‘AC ground not detected’). Tried every which way of grounding the generator but no luck. Can anyone here recommend a small (<2.2kW) generator that works with the SM?
We considered towing the bike across the playa with regen braking on.... really wanted to ride.
Salamander
Burns, OR
Is this the same problem as these guys are having?
External Charger Fault???!!!
It's a different error, but wisdom shared in that thread did point the way. It seems like any generator with a floating neutral will cause this problem when charging the SM. I ultimately tied the AC neutral wire from the generator to the generator ground (like this) and was able to charge no problem.
