- Massachusetts
It will only be a matter of time until competition forces the prices down on batteries, while there will be increases in performance. And if 3k goes to 1.5k E will be an even better deal..
I got an EcoFlow Delta Pro ~1000.00 dollars off from a year or so ago 33% discount. Also portable solar panels are down a lot too. At least here in the US if the bullshit tariffs/taxes were taken off we could probably get panels for even less. You probably have the same in the EU.BTW, I hope that the price of power stations drops significantly as well since I'd really like to have one. Last time I checked, some days ago, they were still pretty expensive.
I've just checked: the same power station retails for 2,400 € discounted here. Refurbished ones don't cost much less than new ones. I hope it's just a matter of time and prices get lower here, too.I got an EcoFlow Delta Pro ~1000.00 dollars off from a year or so ago 33% discount. Also portable solar panels are down a lot too. At least here in the US if the bullshit tariffs/taxes were taken off we could probably get panels for even less. You probably have the same in the EU.
Yes, I had a 2018 Alta MXR for 3 years, put 230 hours on it, around 2500 miles. Always charged it to 100% and ran it down to totally dead every ride. Towards the end I definitely saw a drop off in range. I will say though, I feel like mine got less range than others did from the get-go from the guy I bought it off of. I am a very aggressive rider though.Our surron and freeride E have been in use for 3 and 2 years with no big drop off in how long each full charge lasts, What are people expecting from the stark and what is the manufactures warranty going to cover? At over £6000 a go I do not want to be buying many of those over the bikes lifetime or I might as well run 4 stroke MX bikes.
Did anyone run an Alta long enough to see a drop off in the battery?
Might it be possible to get the cells changed in the stark battery when the time does come?
No the surron only has one charge speed as far as I know, the freeride has fast and slow mostly charge it on slow to hopefully give the battery less of a hard time.UK LEE you can change the charge rate on a surron easily
slow charging is best
battery life shouldn't be a problem on starks
or most other brands.
Its good to not let any battery run flat
but its not a killer they are hardy.
What would be great would be if in situ upgrades were possible. So the platform would remain intact (connectors & etc) and the user would get the improvements with upgraded cell capacity.Might be true. However i can't put the 7,2 in my Stark MX since the connectors etc are different.
