Silent But Dirty
Alta North
- Canada
Lucky me I already have a new spareSo when is an aluminum subframe going to be available....
Holy crap!For reference, that means that more than 3 tons of pressure was applied to that part (actually probably way more since we had only tested the subframe as a stand-alone).
You're lucky you are going to recover 100%.
My personal thoughts are that the above part should be fabricated to just withstand riding inputs thus making it a sacrificial part - really hate to damage the main motor housing /frame /etcShortly after i bought my bike i had a bad crash that cracked my original subframe in the same spot. However, mine was only a 2" crack near the upper left mounting point. Must be a high stress area on the subframe. After that happened I order 2 OEM replacements while i had the chance. I installed one on the bike and still have another as a backup. I plan on attempting to fix my original subframe thats cracked or using it as a test mule for a custom made metal replacement.
Charging issue: Static green light.. | Stark Varg -- General | 2 | ||
Charging speed issue | Stark Varg -- General | 2 | ||
E | Stark Varg charging/starting issue | Electric Powertrain | 6 |
