Lackluster Cooling System Performance
You can only start the fan and pump when it's charging and i usually do.
I also use a big fan to blow past the battery. Not very focussed. But again, i allready had it, it uses 60W so the generator doesn't mind.
And again, very minimal affect if any but also very cheap. If you don't run dirty enviroments: Cut or drill the rear part of the front fender. More air flow over the battery and more towards the cooling and fan.
markhamr
blaxlands creek australia
ceramic coating on the back of the battery case
it will be getting heat sink
im thinking about sm not that ive done any
just throwing ideas around.
i thought the down tubes could be a great idea.added extras
I dont have a heat problem just run mx a bit of off road farm bike
