LIGHTING UP MX VERSION
Bpspecs
Mountain West
So, outside of Ti bolt kit and pegs offered by Stark has anyone figured out how to shed more pounds/Kg off this mx version. Any arena cross racers on here? I know it rides light but when you tip over in a corner or have to lift bike on a stand it’s a 160+ lb pig.
Put an air fork on it - with the WP AER it is another 3lb and you will feel the lighter front end. Easiest way is to use KYB uppers with the AER lowers and cartridges. KTM axle and you are good to go - Brembo brake and wheel just bolts up, same offset.
