WoodsWeapon
- USA
I just removed my rear brake pedal to clean out the toothpaste, add a Fasstco spring, and some cleats to the tip. I have the pedal, steel sleeve with Orings, and the bolt. Is there another bushing that should be inside of the sleeve? In other words, I have an M8 bolt going into a 12mm hole. Other than the countersunk pedal bolt and a mm or two of steel, theres nothing else to keep the pedal from getting pushed at an angle. Seems its gonna wear pretty quick?
