MoM - Motorcycle Owners Manual
Bionicman
E powertrain proponent
WA
Owners Manual
reading the MoM with some observations
page 11
charging porocedure
  • Plug charger into source
  • Plug charger into bike
  • Key to ON
  • Run switch to ON
  • Key to OFF
Allowing charging cycle
Can you skip step 3 & just activate the run switch?
charging outdoors? Guess that eliminates living room storage in a climate controlled space for battery longevity!
Page 13
Don’t ride during a lightning storm!!
Page 25
“raise rear wheel into position”
So the swingarm & rear brake caliper don’t have a lip
similar to KTM’s that require the wheel lift & slid into place?
Page 26
Gear oil replacement specs
every 40 hrs
Page 75
1 hour to change coolant with the pump running
How many beers is that!?
Page 84
Anyone have to replace that 9v battery in the motor controller yet?
Judaslefourbe
Brisbane, CA
Sadly no. You can skip step 4 if you leave the run switch ON though.
Correct.
every 40 hrs
This is incorrect and will be fixed. Oil change every 100 hours is plenty. We recommend Lucas Oil 75W90.
It is now down to 30 minutes. If you use a funnel big enough (like the one we provide dealers), you can let the bike pump without watching.
The 9V we specified is located in the ACM and should have enough energy for 10 years. That being said we have seen some failures where the 9V gets drained prematurely. If that happens, you will see a warning message on the display.
My suggestion with an electric bike is to always always switch to off when you are off the bike, or even when on the bike, but on a break.
No engine sound or clutch to modulate the power, so the throttle can be accidently twisted. Make it a habbit.
