Need a grip, rear light and reflector
craigunger
Bellevue, WA
Hi there does anyone know where i can get a grip, rear light, and reflector for the 2019 Alta EXR. I am guessing these are all manufactures by other companies so replacements are available..
Thanks!
Craig
Grips are Renthal grips.
If you need the reflector and turn signal (common on alot of bikes but its terminated specfically for the Alta harness), shoot me a PM. I have those parts available.
evh1
Montgomery, AL
Caryder
Phoenix AZ
Thanks!
Craig
One of the first things I did to my EXR was remove the reflectors. As for the turn signal, I’d use a fine file then emery paper. Same for the number plate. Since the turn signal is a flat finish that’ll probably look okay, but on the number plate go with the custom number plate backing already suggested and just cover the issue like using wallpaper. :)
