Vntgmbk
- Eastern Pa
Hello,
I recently got a 2017 Redshift MX and an Alta Rapid Charger. The Charger has no plug on it as the 240V Connector was with it but had been taken off. I followed instructions on this forum to convert it to a 120V Plug and did it successfully and was able to charge the bike. My bike had a nearly drained battery so I figured it would take a few hours to charge it completely from what I read on here. So about 90 min into the charge I noticed the fan on the rapid charger had not started( assumed it was controlled by a thermistor) and the charger was getting hot. I stopped the charge( for safety reasons to give the charger a chance cool down. I unscrewed the top part of the charger and moved it forward to allow the heat to escape an also placed a small fan to blow on the charger while it finished the charge which seem to work well. My questions are:
1 Are these fans known to be bad and not start?
2. Is this fan not starting as it is looking for the 240V somewhere in the circuit?
3. Is there any way to bypass the thermistor(the fan spins freely)?
4. Has anyone had this problem and if so how did you resolve it?
Thanks in Advance for any Help you can Provide me!
