Please Help! KTM Freeride exc Brake Light
ryanmx48
new hampshire
any body know how tomorrow convert the stock taillight too also works as a brakelight? Haven’t uses hydraulic pressures switches in the past but can’t find anything. Mine is a 2022 if that matters.
Thanks
Gtrbo1
Long Island, ny
Just a heads up I have 4- 2021 Freeride E’s and mine all came with brake light, high beam and a horn. where did yours come from. Mine were PA.
smdub
maryland
Mine is a 2020. Also has a working brake light from the factory. The little switches are activated by the inner tips of the brake levers. They are not tied into the hydraulics.
standbyu
Portland
Thanks
some are 1 pitch
RJS
Kirkland WA
Mine also had the brake light. What mine did not have was the lower part of the switch gear that incorporates the turn signal selector, and the wiring harness did not have provision for turn signals.
