Power Upgrade on the Varg
Although I don't know much about electronics, I think that trying to hack the Varg would be a very bad idea and I will tell you why by reporting to you a story a marshall told me in a supermoto/sportbikes track:
One day a customer of the track entered it riding his 1000cc sportsbike whose throttle had a ride by wire system. Someone had modified the electronics of the motorcycle, I think the ECU, to somehow make it faster and, despite the fact that inititally the bike looked like it was working fine, at the end of a straightaway it just went straight against the barriers and it turned out that the throttle stayed 100% open despite the fact that the rider turned the throttle tube on the handlebar to the closed position. The rider died because of the accident.
Now, I don't know whether the story is true or maybe the marshall was simply discouraging people from doing certain things, but I surely don't want to try anything like that with my vehicles.
BTW I tried to press the power button of the Varg while applying throttle and the bike slowed down, so if I will ever end up in a whisky throttle situation or if the throttle is locked open I think I will personally try that; do the same at your risk, though, because as far as I know this is not an approved procedure.
I've stuck throttles on ye olde carb'd bikes too. No fly by wire required. Fix was the same, clutch then kill switch?
That will surely work with an ICE bike with a carburator: I get that the clutch disengages the engine mechanically and, thanks to the kill switch, the spark plug won't ignite any more fuel. Maybe it would have worked with the sportsbike of my example but the rider panicked.
On an electric bike without a clutch and with a kill switch that is an electronic control, maybe not, especially if the cause is a software malfunction. Even if the kill switch worked, since nobody rides keeping the thumb on the on/of button, by the time the rider realizes what's happening and tries that, he could have already ended up into the bleachers.
Kurlon
Maine
This is one area Stark will HAVE to address, there needs to be a positive, confirmed, no questions, no ifs, ands or buts kill button that is obvious. If you look at rules for electric bikes in other formats they typically also mandate a positive battery disconnect that is obvious and accessible without tools.
On the flip side, one positive for a runaway Stark, it just can't reach the speeds a full on 1000cc superbike can at the moment. :D
Swank171
Just wait until the government gets involved and our wireless 4g fancy bikes wont work unless its on a designated space haha. No free riding for us.
Swank171
Yep. So crazy once we are fully “electric” these connected devices can be simply deactivated….i love the innovation but definitely see the possible downsides to some of the “tech”
mike61
Future is here.
I suppose that most modern vehicles are "online" and prepared for remote ON/OFF and more.
Slowstrak
califorina
I guess I did not see any post on the subject and for those that wonder if it is possible to upgrade from a 60hp to 80hp it appears that it is possible. I was browsing the app this morning in search of options for hand guards and found the power upgrade option :)
I am glad to see that if I survive my current set up long enough I have more options to end myself.
Anybody has done the upgrade? Was the process smooth?
Hi, I have a question. Looked under parts for power upgrade and can't see anything directing me to it. Could you let me know how you were able to locate it?
markhamr
blaxlands creek australia
I thought it was just the same bike
When I bought mine both where listed for the same price here so
I thought it was insurance based or something to do with class racing
I am sure someone will find the white wire to cut (e joke)
I can understand why there would be a charge to swap it over
Probably a full reset and you may lose all previous data too.
wfopete
Land of NOD
Not much difference than checking the high-performance option on a 1969 Chevelle. Be happy it's as seamless as just paying for it as opposed to taking the engine out or rebuilding it with the high performance parts. Of course a 1969 Chevelle is pretty much hack proof :D
