- Canton, Ohio
I understand the Stark charger is the same as the Alta charger (please correct me if that is not the case).
A nema 6-50 receptacle used for a 240v welder has no neutral, only L1, L2, and ground.
So, I can make an adapter 6-50p to L14-30r, which will have no neutral.
Will this work with the Stark charger, or does it need a neutral?
THANKS!
THANKS!
