Rear suspension play
revsplinter
kc
Anyone pick up the rear tire with it on a stand and feel the rear has slop? Mine only has 6 hours and has a tiny bit of up and down play. I checked with another Varg at the track and he had the same amount of play.
yes just checked mine since you pointed it out
has a minimal amount of play like a notch (less than 2 mm )
I will investigate further
might be nothing too
seems to be in the suspension
It is a build up of 5 pivot points in the shock mounts and rising rate linkages, a tiny bit in each, Much the same set up as most MX/Enduro bikes with the exception of ktm pds.
I noticed some play in mine at relatively low hours compared to what I would expect on our Yamaha's. Maybe the bearing to bushing clearance wants tightening up by a few microns.
