Redshift charging connector type
AnthonyZ
Bay Area, CA
Can't find the answer to this on here, so sorry if this is a repeat question.
What connector type is the charging port on the E/MXR?
Is it proprietary?
Is there a source?
Anyone happen to have a wiring diagram?
Theres no 120Ohm resistor..but the PN is close. Do you need a harness? Or the opposing end?
I'll eventually need a cable with the female (charger) side for a project I'm working on.
No urgent need, able to charge the bike and everything at the moment.
Thanks for the tip on the resistor. The CAN terminating resistor is at the factory charger?
I measure 120 ohms (CAN terminator) across 2 of the small pins for both the shell-size-12 Varg (pins D & E) and the shell-size-10 Alta (pins C & B) - while they are both wired to the Elcon, therefore not sure if there is a resistor inside the Souriau plug or on the Elcon PCB (technically, this termination should be at the extreme ends of the source and loads)
