Help Needed removing the front sprocket
I'm going to remove the front sprocket to replace it and I'm afraid it won't be a dull job like it could seem.
The front sprockets I have dealt with so far either had a nut and a locking washer with tabs or a circlip.
Apparently, the Varg has a KTM style bolt with threadlocker and I've read threads on other forums in which people asked for help after having snapped the bolt [edit: I mean with KTMs, no Starks so far] .I've read that the Varg bolt is stubborn, too.
In the official Stark powerunit replacement video, they say that, if the nut feels too tight during removal, a heat gun should be used.
Now, according to Henkel's site, the 250°C/550°F required for high strength red Loctite sound too dangerous for both the oil seal and the countershaft sprocket side o-ring, P/N STD-OR-0005, that I haven't understood where is located. I guess it should have been wiser to order both the seal and the oring together with the sprocket, just in case. I also think that cooling down the seal with water or air while heating the bolt wouldn't be effective because I still can't cool down the lip of the seal that contacts the countershaft.
Let's not forget that there are permanents magnet in the motor that surely dislike a lot of heat.
So, for those of you who have already removed it, have you noticed the color of the threadlocker? I've read that the temperature to remove the medium stength one is lower.
When periodically checking the torque, I noticed that it's pretty hard to prevent the rear wheel from rotating with my left hand rear brake and I'm afraid that I could damage something if I use crawl mode or reverse mode. I'll try and put some object in front of the rear wheel while applying weight to the footpes, so that the object will get wedged, hopefully preventing the wheel from spinning.
I used an impact without heat.
I put it back on also with impact, and no new loctite.
Hasn't come loose over hundreds of hours.
With the chain in place, I put a bar or wrench through the rear sprocket hole to hold it against the swingarm while turning the front sprocket bolt with the torque wrench or breaker bar. To retighten, just move the bar to hold wheel turning in reverse direction.
I’m planning to clean the old thread locker and use new medium strength thread locker just to be safe.
I check that the fasteners are tight, on a regular basis, anyways.
Thanks to everybody for the answers so far (I haven’t done the job yet because I’m still waiting for the parts).
Both times I've changed it, I've done it with the help of a friend. He sits on the bike pressing both brakes very hard, otherwise the bike moves, and I use the tool to loosen the screw very forcefully. It's quite tight, but it comes out.
yep, it was tight but no heat required. The idea of putting it in crawl mode sounds like a good idea to hold the rear in place.
As per Stark’s power unit replacement video, the front sprocket bolt, during reassembly, should be tightened at 80 Nm: it sounds like much. I haven’t found other sources of information about it in their manuals or guides. Have you really tightened it so much?
I just used my 120V 1/2” drive impact, and it’s good, didn’t check the torque.
I've removed the bolt in this way:
The bolt looks like an M14 X 1.5 steel bolt, maybe heat treated, whose thread has at least 8 coils. Therefore, it's quite likely that something like this can withstand 80 Nm and that it can even withstand more than that during loosening while some torque is added from the threadlocker.
The old threadlocker looks mostly white now but I've seen some blue residues so I guess that medium strength threadlocker has been used.
Those guys reporting snapped bolts on KTMs mentioned M10 threads at 60 Nm + high strength red threadocker.
Now, to me, it looks like Stark has borrowed the design from KTM but that they've also improved it with logical decisions.
The old threalocker, BTW, is still hindering the rotation of the nut, probably generating something like 20 Nm of torque, so if I apply 80 Nm without removing it, I will be probably generating the equivalent clamping force of something like 60 Nm, that's why I think that I'll remove it and apply new one.
i tightened it to 80nm 3 times on my bike and 2 times on a friends bike, dont worry, it will be okey
