markhamr
- blaxlands creek australia
can you charge it off a 110 volt wall socket
It might be part of the scam, but it is a lot of trouble to scam this far and to take a product this far --though it has been done before. If it is a scam Lehtimaki is going to have lose weight if he wants to compete with the top rock stars in the snake oil field:This vid is really great and knowledgeable.
Independent testing is a must but as he says, probably the most important and easiest test to prove it is indeed a solid state battery would have been to simply ask VTT to cut the cell in half so... why didn't they? I mean, they claim it's cheaper to produce.
So basically they're selling a 400 Wh/kg without Li that has all the hallmarks of a 300 Wh/kg Li battery. Best case scenario looks like it's a top NMC battery, with slightly better energy density than Molicel P60B (7%) and maybe able to charge twice as fast.
He's pointing out, as I did, that we'll need proof that all independent tests will be carried on the same cells (at least same cells chemistry), this is quite important.
oh sorry i didnt see itPosted it some time ago on this forum. Quite some people thought fake. I'm not sure.
I could be mistaken about this vid, but one of these cases was the result of a user modification.oh sorry i didnt see it
the guy said that Stark is going to fix it with the warranty. The screen turns into the problem interface, i think its a very isolated case but it's true IMO
That will be very cool.we were talking about this! older starks will be compatible with future better batteries, wtf!
This will be more like the 7.2kWh battery replacing a 6.5 in an MX1.0. Maybe the is an 8.0 in a couple of years?we were talking about this! older starks will be compatible with future better batteries, wtf!
yes, all Stark next batteries will be on 27120This will be more like the 7.2kWh battery replacing a 6.5 in an MX1.0. Maybe the is an 8.0 in a couple of years?
The 300km range (200 irl) likely be based on the 27120 cells
