SHSMITH76
- New Hampshire
Like, my Stark will live in my house, so I want to be certain that it won't catch fire while charging.
Indeed.
I'll only charge while I'm available to monitor things.
Once charged up - is it a safer condition to disconnect the battery when not in use ? Say if it sits for a week or more before next ride.
EU has a bunch of standards for electric vehicle batteries that manufacturers must meet to be able to sell EVs in Europe. Homologation means meeting these standards. They cover battery safety, mechanical shock, vibration testing, fire safety, shorts protection, etc... I thinkEU is also bringing in battery recycling requirements to make it easier to recycle batteries at end of life.
Arcplus has battery testing facilities in Barcelona.
I thought these were just for on-road vehicles, but I'm not an expert in the legislation. Anyway, if someone is Europe is handing over € 12 900 then it makes sense for Stark to meet relevant European standards even if they don't legally have to.
Also, comparing the new batteries in these pics (and also in the pics of the grey Starks) versus the original design on the red bikes, it looks like they've really reshaped the front top corner of the battery. They've possibly moved the big battery connectors from the top back of the battery to the front? I'm also squinting at some of the pics and maybe there's some kind of control unit hidden under the carbon shroud, just behind the head tube?
The battery can choose when to connect to the HV cables using a pair of internal switches called contactors. While the bike is idle (not charging or riding) it opens the contactors to separate the battery from the rest of the HV system. So while the bike is sitting, unplugging the HV connector wouldn't change anything safety related.Indeed.
OK thanks Guys.
Would one be shortening the lifespan or diminish the power of a battery significantly if winter storage in a mostly cold ( Indiana ) climate is in an unheated garage ?
Sure would be easy to just bring a battery inside, but alas ..
There will be marginally more degradation if stored at low temperatures, but I wouldnt worry too much unless its getting to -20 to -30 degrees C. However, you should never charge the bike when it is cold. Always try to warm it up to around 5 degrees C first.OK thanks Guys.
Indeed.
Thanks.
Doesn't sound like one would need to be too concerned about the battery, the bike can come inside during the worst ( Jan, Feb ) months, not really riding much if any during that time in this climate.
The 12V comment is intriguing though .. is there a usable 12V output to power an LED headlight or similar if desired ?
California does not qualify as cold.Both my Altas even though are in CA, live in unheated garages and have never had any performance drops due to cold.
Im sure there's a million other priorities for Stark at this time and it is marketed as a track bike, but doesn't this seem like an oversight? Eg a presumably simple add, low cost, extra revenue if coupled with a plug and play light kit, etc and yet impactful for a reasonable percentage of customers? Guessing an "enduro" version would have such, but doesn't help first customers..hopefully"rigging" isn't that difficult or a 3rd party makes an easy solution eventually. Thanks for sharing, at least answers that question definitively.There is no spare output from the VCU (vehicle control unit) to drive a LED headlight. However, the DC - DC can put out enough current to drive a LED headlight in addition to the coolant pump, cooling fan, etc. So in theory it is possible to "rig something up".
Fair enough, appreciate the inputs and info - very cool! And the spare pins at least give a path to a solution (as you said) - so we're in business!The physical space for the VCU (vehicle control unit) is very tight. We might have been able to put an output for a headlight but that is about it. So, no blinkers, tail light, etc. However, there are 4 spare pins. Two for +12V, NEG/Chassis. Two for communication. That can then connect to a LCM (light control module) which connects to the lights and switches on the handlebars. That is basically the only approach that works for this particular case.
Thanks ! Good news indeed.There is no spare output from the VCU (vehicle control unit) to drive a LED headlight. However, the DC - DC can put out enough current to drive a LED headlight in addition to the coolant pump, cooling fan, etc. So in theory it is possible to "rig something up".
Cold enough . I wants my 70 degrees back!California does not qualify as cold.
My bikes have been fine staying uncovered in an unheated garage in the Toronto or Boston areas (down to -30C). Batteries will do fine but watch for tires and such.
