Hi, just resurrecting this old thread cause I changed some SM tyres over to tubeless.
It started with a nail in my rear tyre, I stopped cause it felt like a rock was jammed in the tread, ended up being a nail on inspection. I began to slowly pull it out and stopped when I heard air leaking. I left it there and immediately rode home. I still had pressure when I got home thankfully. I then I pulled the nail and it deflated fast.
I've driven over some nails and screws before in cars and fixed them with plugs so I decided to convert my SM wheels to tubeless in case this happens again.
I considered the outex system but also found others had success with 3M extreme sealing tape: 4411N you can also use 4412N or the 4412B (the 1N is 1mm thick, transparent and the 2B 2mm thick black etc.) I didnt choose outex simply because they send the kit with silver valve stems and I wanted black. Then buying the sealing tape means I could make several tyres tubeless for the same price, and use the leftover tape for other jobs.
Here is my process:
- removed tyre from the rim
- removed rim tape from the spoke nipples and cleaned the rim.
- applied tape patches (gorilla tape) over the spoke nipples. (This helps avoid the sealing tape from tearing if you need to adjust spoke tension at some point)
- taped the whole way around the rim with the extreme sealing tape 4411N. (I chose 1mm because I heard it is easier to work with and conform over the nipples and it should be half the weight while still sealing as expected)
- I covered where the tape join is with a small strip across the join.
- I taped over the sealing tape in the same way as the outex system to protect the edges of the sealing tape when mounting the tyre
- installed the valve
- fixed the nail hole from the inside of the tyre
- remounted the tyre and inflated.
Easy process, I encourage others to try.
