FYR
- Central Valley, CA
Just ordered the oil. How are you getting the oil out, suction pump?
Besides frequently changing this gear oil and keeping the chain clean and lubed, anything else I need to worry about?
As others have mentioned, there's a small drain plug and it also has a copper crush washer. They recommend a new washer whenever replacing the plug, but I've re-used mine several times and have no leaking or seeping issue. Stark does a great job with their service videos, it's worth it to go into your account and search for the one that pertains to your particular need, or you can search YouTube -
The oil change process is best done with removal of the skid pan and that's also a good opportunity to clean all the dirt and debris that's been trapped in it. Pay attention to the torque spec's and use the great tools that came with your bike. The whole process can be done in very little time if you have all the bits needed.
