Motophyllic
- NY
If anyone has a rear hand brake for the 2019 EXR, I am looking to buy one.
This is the route I went (instead of factory LHRB). Spent under $200 in parts (ebayed a used clutch perch). Works PERFECTLY and would hate going back to an ICE bike!Hi there. If you read this thread: The Alta Factory LHRB they talk about the part numbers needed to order the parts yourself.
We've heard about this before. This is a leaky bottom seal on the insert. Either a bad seal or a bad installation.We did some experimentation with the LHRB kit from Alta here at the dealership on a 2019 EXR. To retain the brake light switch, we tried plumbing the LHRB line into the same connection as the line from the foot brake pedal. The increased pressure from both levers blows the site glass out of the master cylinder. We learned this the hard way.
