Sold WP Shock / Race Tech piston & nitrogen valve / Zeta lowering spacer / DCC check valve etc.
Alta MXR WP shock (stamped -01) w/Race Tech SMGV 5003 Gold Valve piston kit & SPNV 0512 nitrogen charging screw, Zeta ZE56-32250 10mm lowering spacer, and custom-machined graphite-impregnated nylon check valve / spring for Dual Compression Control (replaces DCC shim stack). 50+ Race Tech kit shims / Alta ver. -01 comp. & rebound plus ver. -02 rebound-only shim sets / RT hardware & DVS-recommended shim list included, as well as all original parts. Reservoir piston set 10mm down from reservoir top. Shock has @ 30 hrs trail + street on it, body looks excellent inside and out (the main bore has paper-towel lint in it that looks like pitting in the camera flash), reservoir not removed. Check valve / Race Tech / Zeta parts & OEM Alta 60 spring all new & unused.
Price $250. I'm just trying to recoup the money I spent on the new stuff, the shock & spring are basically freebies. :) Ray
