wwmotors
- Bavaria Germany
Hello Alta Owners, is there someone, who runs a SM in Europe? My questions are the following:
Due to the fact, that all additional chargers run on 110 and 240 VAC, does the SM also charge on 240 VAC with the onboardcharger?
If not, I have to use an inverter, what is pretty unpracticable! Slow charging and a heavy part more in the house.
Is it possible, to rebuild the SM technically like an EX and charge it with the standard charger?
Does some one of You provide a standard charging plug for the rebuild, just in case, that will work?
If this is technically possible: How can I upload the EX software, so that the electronic will deal with the changed components?
A lot of questions. Thanks for Your help!
Cheers
WW
Cheers
WW
