Tuner
- El Sobrante, Ca.
For those here that are removing triple clamps, be aware that Alta changed the torque value on the clamp bolts to 14 Nm towards the end.
Yes, this worked! Thanks a lot @Philip!Should I put the two bolts back in and press on them??
Uhh, I think you're talking to yourself...Yes, this worked! Thanks a lot @Philip!
Have rotated steering stems on two of my three bikes and both required a hydraulic press to be pushed out, which I think is normal.
The oval and conical taper fit is mesmerizing. I keep thinking about how to spec the manufacturing tolerances on such a design. It's also very hard to measure these tapers once they are machined. I wonder if Alta had invented this design or copied it from someone else?
Use GoPro to Adjust Suspension | Suspension | 1 | |
R | Some Stark Farkles with Steering Damper | Builds & Supermoto | 1 | |
General YAMAHA’S PROTOTYPE ELECTRONIC POWER STEERING & STABILIZER FOR MOTOCROSS | General Discussion | 1 |
