- SF Bay Area, CA
We cut the limiter wire on the Sur-Ron X after a couple rides at the local off-road park (Carnegie SVRA). My son put about 50 miles on the thing in two days. The thing does have a lot more power without the limiter. The thing has a short wheelbase, so it wants to wheelie, even with my 6'0, 235lb. butt on it. It accelerates quite a bit faster with my 100 lb. son on it. Front brake was squeaky after the first ride, and I'm working to fix that issue. It's got more acceleration that it does stopping power. Minibike power, mountain bike brakes. Not necessarily a good combo.
Fixed the squeaky & weak front brakes by swapping the OEM pads for Shimano H03C pads. Much better stopping power, and they don't fade like the stock ones. They also have built-in cooling fins. The back sides of the original pads literally looked like they had melted from the heat. Hopefully these will last a bit longer. Make sure you use the new spring that come with the pads, as it is slightly shorter than the OEM spring.
