Dmagg
- Charlottesville
I know the 2019 exr is electrically limited to 76mph. Anyone know what the theoretical top speed is? This thing still pulls pretty hard until it hits its limiter. Wouldn’t surprise me if it’s 95 mph+
Test plan:
Stock Alta run up to top speed. Note top speed and local conditions (weather, wind, altitude, etc) for this run and all runs below.
Stock Alta at sustained top speed run until charge is depleted. Note mileage.
Taller gearing run to top speed. Any change?
Taller gearing sustained top speed run until charge is depleted. Note mileage, any change?
Stock Alta with clip ons and TZ250 or similar full body work run up to top speed. (or w/supermoto style wheels/tires)
Stock Alta with clip ons and TZ250 or similar full body work sustained top speed run until charge is depleted. (or w/supermoto style wheels/tires)
Would be a fun exercise.
Anyone taken their Alta to Bonneville yet?
Interesting. Let's see .....
I have a stock ALTA "R" (two in fact).
I have relatively smooth DOT tires that fit the stock wheels.
I have sprockets and spare wheels to change the gear ratios.
I have a roadracing fairing, clip ons, and 17" wheels & tires that will fit an ALTA.
However, two remaining problems for the test plan ....
I don't have a place for a sustained high speed test without danger to myself, others, and my wallet.
I am 6'-3" tall and I am known as 'the moving billboard' in bicycle pacelines.
I suppose someone else will need to pull this off.
Wow. Fantastic results. Anymore details posted anywhere? Thanks for sharing. -Eddie
Remember that tires expand at speed too.
I made a quick theoretical speed calculator for our bikes. Just input the tire diameter (inches) and the mph for each sprocket combination will be computed.
Alta Redshift Sprocket Calculator
View attachment 4093[/MXR Top Speed Test
Your chart is real close![]()
U | Battery top front mount bolts | Stark Varg -- General | 0 | |
Stark makes history: Electric bike takes shock first win against top pro racers in UK championship | Videos | 0 | |
G | Top speed Stark Varg | Builds & Supermoto | 34 |
