Silent But Dirty
Alta North
- Canada
Ouch...
this current stator will desmagnetic a rotor magnits. ))@sergeynik -- If you manage to squeeze 70 or 170hp out of the Alta, I would like to be the first one to know!
While an impressive capability, let's maybe try not to shred the magnetic fields out of our motors... Just right to the ragged edge perhaps.
Definitely. But in a good way. Probably.Are you correctly implying that I am small minded?
Can you replace the exploded SMD transistor and the surface mount resistor that appears to have been blown off its pads, and run jumpers from the other side of the board in place of the burned traces and then test the unit. I think the transistors energize the windings of the relays and the relays function to connect and disconnect the battery from the charger.day 2 (problem found)
schematic diagram
tested hi voltage
this connector seal passes antifreeze inside the unit
View attachment 4148View attachment 4149
You could always take the top cover off your battery (be careful as one of the battery connections to/through the BMS board is a “banana plug” but the other is attached with a wire/guide/cover and screw and this wire must be carefully pulled to allow enough slack to remove the cover) and run two wires to the outside (thus bypassing the contactors in the lid) to charge the battery with a charger of your choice or design. Unfortunately your cells won’t get balanced, but it is a way you could charge.Can you replace the exploded SMD transistor and the surface mount resistor that appears to have been blown off its pads, and run jumpers from the other side of the board in place of the burned traces and then test the unit. I think the transistors energize the windings of the relays and the relays function to connect and disconnect the battery from the charger.
I don’t have multi tool or any other CAN tool that doesn’t automatically translate, otherwise I would gladly share the ID’s and maybe even put them on a graph/table with time and battery voltage.Internal ALTA can 500kbit /s
DDCP Module
100ms period
dccp-analogs 0x660 00 00 00 00 0d 37
charger status 0x652 08 00 00 e7 ff ff ff ff
charger control 0x650 00 00 00 00 04
1sec period
0x1ffff010 00 02 01 06 5b 44 fa 69
0x1ffff018 87 00 00
The module seems to have to be done by itself. Help with these CAN ID what you have there when charging your motorcycle
External charger can 250kbit/s
https://www.nothnagel-marine.de/media/downloads/Elcon_TCCH/ElCon_Ladegerät_CAN-Bus-Communication-Spec.pdf
It seems like the low voltage (master MCU) is still working and can communicate. I can see where the heat from the exploded transistor burned all the way through the board. The worst damage to the slave/high voltage section appears to be the long burned trace. Why not take a tiny grinder and remove traces that lead to damaged areas, solder jumpers to origins of traces, build a breadboard with new transistor, resistor and any other damaged components there may be, attach jumpers to it and test?Might be fun, especially if it works. As long as the IC’s on the board are not compromised, it seems like it could be repairable.this module two part low voltage and hi voltage
low voltage including master MCU 2 x can bus, relays HV, spi bus to slave mcu . only digital I/O
isolated hi voltage part including slave MCU
analog measuring Voltage in HV bus
isolation ADUM4154 ( SPIsolator™ digital isolator) and dcdc 12->5v
