SarahShoemaker
- Shutesbury, MA
That’s so amazing, thank you so much for helping with this!! So glad it was a fairly simple and inexpensive fix! Thanks a million
Just curious, but what is the purpose of the 9v battery? These bikes seem pretty rock solid, but we all know 9v batteries don’t last forever.Congrats!!!
It is difficult but possible to replace the 9V battery without removing the main battery. Just need to wiggle things a lot. I was able to remove and check mine before I had no choice but to start swapping bigger parts between my bikes.
As in the 9V battery was engineered to last 10 years?Correct. The battery was engineered to last ten years. If there is a parasitic draw, that will shorten its life.
We designed the firmware to work around that specific part number.s it true that no other 9V will work for this? Only the Energizer Lithium?
It does not mean other models won't work, but the FW might see them as faulty..
It was bcu issues. big thanks to @Mark911 for all the help to get it all figured out, once the new chips show up it should be cruising again.BCU issue.
It's difficult to say if this bike's failure was a parasitic draw or faulty 9v.
