240V Inverter in a Van or Truck
Chief Happiness Officer
I have been researching how to install a big 12V - 240V inverter in my van. Not long ago @WoodsWeapon mentioned a guy on VitalMX who had such a setup. I managed to get a hold of him, but he referred me to his more electrically skilled friend, who actually came up with this installation recipe. Here is the recipe:
RECIPE #1
1) Buy and install a dual alternator kit. Nations Starter & Alternator offers Multiple Alternator Kits The prices range from $650 for popular trucks with just one upgraded alternator to almost $2K for dual upgraded alternators and a regulator for more exotic Sprinter and ProMaster vans. You may want to consider a triple or a quad alternator kit too, hehe.
2) Buy and install a 400W 12V - 240V pure sine wave inverter. Those cost about $1K. This one is a good option: 4000 Watt Pure Sine Inverter Charger - 12 Vdc to 120/240 Vac , and so probably this one: Discount China 4000W Peak 12000W DC24V Pure Sine Wave Inverter With Charger 65AMP LCD Screen - www.sungoldpower.com . I recommend you check their Amazon ratings as well. I like the first one because, apparently, it can provide 110V and 240V simultaneously.
3) Install two deep-cycle marine batteries. Four batteries is recommended in order to charge a Redshift from zero. I am not sure about their required capacity, but I imagine the price can be around $1K or so.
4) A knowledgeable guy recommended a high idle kit for the van/truck. It keeps the RPM above the default 700-800 rpm. Apparently the regular low idle still discharges the deep cycle batteries before the Redshift is fully charged. The high idle kit can bump it up to about 1800-2000 rpm while charging.
That's it.
Some more important details that I almost forgot about:
Two deep cycle batteries is okay, but you really need to get two more to be able to charge from 0%-100% without having to take a break and let the batteries catch up.
WIRE Gauge has to be thick otherwise you are going to burn it up and go through those.
Fusing -- make sure to get the correct ones and sized properly. You don't want to burn anything up.
High Idle kit is key.
What I do not get is, if I install two 280A alternators in my van, why would I even need any additional batteries? 2 alternators * 280A * 12V = 6,720W. This should be a plenty of power to run all the van's electrical systems and the Rapid charger simultaneously. Why would I need any deep cycle batteries at all?
It looks like the alternators do not really produce their rated power. But even the Hot Idle Amperage @ 200F is 165A. That is still 2 alternators * 165A * 12V = 3,960W. Bump up the idle speed and there will be more power available.
Where does my math fail?
270XP alternators specs: 270 Amp High Output Alternator for 2014-2015 Dodge ProMaster Work & Cargo Van
Your math seems fine, but are you certain these alternators can be paralleled into a single DC load? I couldn't find anything on point at the site FAQ, but I did see mention of an 'alternator excitation harness' which apparently provides on-demand alternator switching (presumably for separate loads).
Re the battery... I don't think I'd connect any automotive-type 'dumb' battery to a system this powerful without some kind of interface unit, to prevent overcharging or excessive discharge rate.
don't forget your high idle vehicle will be 'sipping' the petro to recharge that battery bank all day not to mention the wear & tear on your mode of transportation to the track!
Yeah, I remember that. Even with a low idle my van still consumes a lot of gas and produces a lot of heat, which makes standing right outside of it uncomfortable on a hot sunny day. Often a worse kind of uncomfortable than standing near a loud generator.
That 10kw generator is 540 rpm PTO driven (25hp compact tractor minimum). A truck PTO is a different animal, usually much higher rpms to drive a hydraulic pump.
or what if Alta sold battery packs to refill the bikes battery then you could leave that noisy generator refilling the 'charging' station while your out roosting @Judaslefourbe ;)
Yep. Sounds like bringing a spare charged battery with you is a very attractive option, considering the alternatives. Wish it came with a couple of factory mechanics though to help me swap it.
