I would like to share with Alta community how to DIY an open source CAN Bus adapter cable that could be used with Alta Multitool.
I have tested it on my own MXR and it works great, but a disclaimer - use it at your own risk.
NOTE: I have not updated firmware using this adapter, since my bike is already on the latest one.
Hardware
USB Can Bus adapter
The adapter has to support Lawicel ASCII protocol specified here.
There are multiple adapters available but I have decided to use CANable.
CANable with microUSB connector can be bought here - shipping from US - $29 + shipping
Or on Ebay - shipping from China:
microUSB version - $19.90 + $5 shipping
USB-A version - $19.90 + $5 shipping
Plug that connects to Alta Can Bus connector - RP13A-12PA-13SC(71) made by HRS.
It can be bough from Digi-Key for $6 - RP13A-12PA-13SC(71).
Contacts for the plug have to be bought separately - 2 pcs. - $0.41 - RP13A-SC-121
Some kind of plastic enclosure for the CANable to keep it from shorting to metallic parts on the bike.
Assembly
Crimp or solder two wires to contacts and insert contacts into positions 7 and 11, looking at the front of the plug
Connect wire 7 to CANH and wire 11 to CANL on the CANable.
Software
Follow instructions by TCMB371 here to install Alta Multitool
Connect CANable to any of the USB ports on your laptop.
Open a terminal window and run "ls /dev/ttyA*" command, as a response you should see:
/dev/ttyACM0
Run "lsusb" command. Among the USB devices you should see one that matches ID below:
Bus 001 Device 092: ID ad50:60c4
Download canable.py.zip file attached in this post
Unzip it and place it in the "AltaMT-Engineering/redshift_multitool-3.37.11.ET/redshift_multitool/_ext_python_lib/" directory
Open "AltaMT-Engineering/redshift_multitool-3.37.11.ET/redshift_multitool/_ext_python_lib/canusb2.py" file in your favorite editor and modify line 87 from:
self._can_source = lawicel.CANUSB(device=device, bitrate=bitrate, filters=filters,
to:
self._can_source = canable.CANUSB(device=device, bitrate=bitrate, filters=filters,
Save the file and run install script for the Multitool, "sudo python setup.py install" from "AltaMT-Engineering/redshift_multitool-3.37.11.ET/" directory
Start the Multitool "sudo redshift_multitool"
Multitool should detect CANbus adapter and start in full mode.
Shut down Multitool.
Connect plug to your Alta and turn on the bike.
Start Multitool and it should connect to your bike.
If you want to use Lawicel can adapter just change back line 87 in the canusb2.py file and run install command again.
Hardware
USB Can Bus adapter
Assembly
Software
/dev/ttyACM0
to:
