Potatonet
- Wild West County
Pinging to the top, everyone is lined up but the guy with the parts at this point.
must use more rockets
Awesome. I like to see the progress photos of this actually happening.Still printing. First print failed. Second print in progress. I still think this prototype won't fit exactly right but I will take this one and physically modify it so I know where to fix it on the 3d model and try again.
This print also failed... the filament caught and jammed up the system. Enough printed to figure out some errors to correct though so it wasn't a total loss. I may scrap this design and start from scratch or take another approach. The hard part is it is curved in multiple directions and skews some in a couple of these directions which is difficult to accurately measure and model.
I was working on this at one point. It is difficult to get a decent fit without a mold + 3d scanThinking about it instead of reproducing complete shrouds perhaps we could make inserts that sort of snap into the openings between those nasty ribs - it would seem using a scan of the shroud a piece could be 3D printed that fills the hole. Or maybe the inserts are two piece (outside / inside) with small screws that connect them.
Maybe one of the 3D printing guys on forum can comment if this could work
Thoughts
I still think a whole shroud would be best, does Blatant Moto have an actual shroud or just the scan file?. If not....
someone must know where there might be one of the new style ones?.... Maybe?....Rashid sir?
Thanks for the reply. Hopefully he will see this topic has been replied to, and reply!.Blatant Moto has files, there was a plan to get more scan data...dont know where that went. Blatant has mentioned that set is the only new style set.
3D Print Models | Sources for Replacement Parts | 18 | |
Shroud screws | General Discussion | 7 | |
D | Grey front number plate? White or grey fork guards? | Accessories, Plastic, Lights, Bling | 0 |
