- Charlotte, NC
Being able to start every moto with the pack at basically early morning ambient temps (60-70F) is a game changer for me. I usually don't hit the thermal limit on the first moto out in the morning (cold pack and cooler air temperatures). Its after rapid charging + higher ambient temps on my second moto and each moto thereafter where ill hit thermal limit, especially on really hot days. Not to mention charging is initially slower after coming back from a moto since the pack is warm and the charging logic limits max amps until the temps come down.
Id be curious to see if there's any benefit in regards to temperature distribution/gradient throughout the entire pack with the second plate added. Id imagine the heatsink effect from the metal shell + the water cooling setup would help equalize the temperatures across all of the cells (middle cells vs perimeter cells), which should theoretically help with cell life as well.
You touched on it a little, but id be curious if the radiator setup is even worth it. Perhaps precooling the pack is enough to prevent limiting and one could just drain the system before the moto and let the passive heatsink cooling do its thing. Would essentially eliminate the weight penalty when riding, where it matters.
What are the power requirements of a water chiller like that?
