I always just walked off and left the key on while it charges… but I’m a new owner so that is like 10-15 times. Then the bike would be asleep when you get back. Is it normal for the bike to go to sleep if you leave it inactive or after charging? Then key off and back on and “whirr” water pump and blue light. This time, nothing.
Verified the key switch works, I know those rarely break but I had broken the tab off a key and bent it inside this one a couple weeks ago so I checked anyway.
Got as far as dropping the battery and  popping the top off. Pretty simple to get that far but the only troubleshooting info I’ve found on this was for an R pack board. I only looked quickly but i didn’t see the offending chip mentioned for this issue in that case which didn’t surprise me as I assume the boards are different. I think
@Rashid510 may have helped in that case also.
I’ll have to go back and find links to the resources I used but they were almost exclusively from this forum anyway.
I need to get this working again :-( the KTM is a great fun but it’s a play bike and the lack of engine braking drives me a little nuts. It has the rear brakes from an 85 which with no engine braking on a hand brake is rough. They make a kit for the bigger brake caliper/rotor from the 250s and up an easy cheap fix which should solve that problem.
Plug for
@Gtrbo1 who sold me my KTM and is selling a better than showroom one right now in the classifieds.
