Want to buy Timing cover and gear cover gaskets
Trialsman
Pittsburgh
All you have to do is get gasket material at NAPA and trace the cover on it. Cut it out, punch the holes, put sealer on one side and bolt it back together. I have done it on two EXRs now. It's very cheap and doesn't take long to do.
FrancoLizard
North Texas
Thank you @Rashid510 . I have a laser cutter, so I thought it might be a fun experiment to make some gaskets. This assumes that the material is laser-friendly (won't kill me with chlorine gas). If it's not laser friendly, I'll reach out for some gaskets. I appreciate the help.
No problem. Its MP-2N Gasket Material - MP-2N Gasket Material | Custom Die Cutting for MP-2N.'
Which is usually diecut. You might be able to try laser depending on the heat output.
Reactions: #76
