BMS Per-Cell Cost?
boom
West Coast U.S.A.
What are people generally paying, per-cell, for a system which includes:
  • Charging
  • Protections (overcurrent, under-voltage, etc)
  • Active balancing
I'm curious about off-the-shelf systems vs DIY.
For systems based on 18650's or 26650's.
Not counting the cost of the cells, cell enclosures, wiring, etc. Just the circuitry.
  • Charging
  • Active balancing
Pretty common for DIY folks to bypass the protection features and just use it for charging and monitoring. Those can be had for about $50 (I use a Daly). The BMS's that can handle high discharge currents can range from $150 to several hundred depending on how much documentation/features you want it to come with.
can you link to an example? Like this?
