Foss
Stark SME
- Vestal, NY
Hey guys,
Just wanted to share some recent mods others might be looking for or interested. Finally found a perfect fit front disc guard which replaces the OEM wheel spacer. Also Pro Carbon fiber is making a full replacement bash guard for the bike which would look nice. Currently using the Rekluse dual rear braking left hand and peddle. Added the Enzo adjustment for compression change not needing to remove the handle bars. Onegripper seat cover was a bit difficult to install, length was short so you have to really pull the cover and use an air gun staple gun with a wide crown. Deleted the phone mount entirely since the phone popped out a couple times while hitting the larger jumps or flat landing. MX14’s and MX34’s on the rear, no need to add an extra link or change the OEM sprocket.
