Anyone making stronger motor covers yet? Cracked my stock one
Also all that beautifull cnc machined aluminium will get scratched so quickly it's not even funny 😁.
It also looks black oxided and I'm afraid that such a surface treatment would be worn quickly even without accidents, because of the boot rubbing against the cover, especially if there is a foot operated rear brake.
Torpedo
Uk
On only my 2nd ride I damaged the side casing in a little 5mph tumble.
Ordered a replacement from Racetorx late on Sunday, it arrived today (Tuesday) and that's between Christmas and New year. Amazing service, thanks Racetorx IMG_20241231_135019.jpg
Reactions: MVC
Varg75
US
Question on the RACETORX cover. Can I just lay the bike on its side to change or do I need to drain it, to change it? Also anyone now the torque spec on those little bolts as well?
It will be stronger and stiffer. Nice CNC is very much into that. However if that leads to less damage is the question.
Forces might transfer to the rest of the way more expensive casing.
I stick to the OEM wich is quite affordable and life with any cracks etc. It's just one gear and very low oil level. That will life through riding back leaking.
There are few more offerings:
Also much lower price for NiceCNC cover on AliX. Not sure if there is a catch.
I agree with Erwin. OEM cover is cheaper and offers similar protection.
What I want is something that protects the profile and bottom of of the cover and the engine casing.
Nice CNC with Aliexpress i have nothing but good experience in build quality. Their offerings are often at the same or even higher level than other aftermarket brands.
However I look at the side cover as its own ''sacrifice part''. A part that is allowed to die to take one for the team.
I have done a lott of ADV riding in the past, there you see very strong stiff bashplates, rocksolid handguard etc etc. Often the effect of those over the top strong parts is that in a crash they remain intact. But the part they're bolted onto isn't. And that's a shame when that bashplate is connected to the engine casing of the frame.
Especially since, as i described, if this part starts leaking it will still get you home without too serious damage.
I think one of the best things you can come up with is damping like the bashplate of the Stark. The easy DIY would mean some thick rubber over the casing. Like from a ultra heavy duty tyre.
That cover for over the OEM cover might be the best option.
Doesn't protect the motor casing, the bottom or the profile. Attached by glue to the cover. Costs as much as oem cover.
Still waiting for someone to make a more complete protection.
There are plenty of stronger, thicker clutch covers available for the ICE bikes but I've never heard that any of them led to damage on the engine cases. Yes, you can run a 2T for quite some time without (or little) oil and the Varg without a clutch probably quite long but it is not desirable. Especially considering things like water, mud and debris can get into the gearbox as well I would always opt to fix it if possible before continuing. So I think a stronger cover like the Racetorx or NiceCNC is still the best insurance. I'm not a fan of the composite covers as we once had an incident in very muddy conditions where the clutch cover cracked under the composite protector, but the leaking oil was not spotted due to all the mud. Clutch finally burned up.
I have, in Pascuet on a KTM 300.
Then again, all kind of weird and wonderfull damage happens there.
I'll try to describe what happened there (not my bike).
It had one of those more sqaure harder clutch covers. That found a way to hang on to a rock. Although the pieve itself had just a scratch it ended up transfaring so much force it was able to pull on the bolts wich cracked the right hand engine case backwards.
We are talking Pascuet here were all kinds of damage you never thought of occurs though.
I agree. The same thing has been said about the footpegs that some poeple have broken: be careful installing sturdier ones or the side plate may be damaged instead of the pegs.
I've also seen similar things with street bikes or supermotos: people install frame sliders that protrude from the frame, but what if they generate a leverage and bend the frame? Instead of replacing a fairing you may end up with a way more serious damage.
Besides, I am Italian and I have a strong belief: never dare to question the factory. If they have made something in a certain way, they know the reasons, you don't.
This concept is expressed beautifully here @1:56:
:D
Yess and no. Sometimes you do know. Often things are done because of being cheap, or comply to laws etc etc.
However i don't think that's the case with the sidepanel.
I know, I know, I was just kidding.
Haha but you do strike a good point, often if something isn't build to a cheap pricepoint or regulation it's well worth it to take a very deep thought about what and why the factory didn't do what you are about to...
