Nice job cutting it off, very smooth!I cut it off. Also did the "bolt" trick to give me an extra 1" of effective length. Very happy now.
I think the line on the "cylinder" is there to show you where to cut it off, but after seeing the smooth job done by @blbills, I am going to take care to make mine as smoothOr grind it down lol.
I just don’t use a kick stand lol. A tree or wall is good enough for me
I did the initial cut with a simple Dremel tool with a cutoff wheel then finished it off with a bench grinder.I think the line on the "cylinder" is there to show you where to cut it off, but after seeing the smooth job done by @blbills, I am going to take care to make mine as smooth
Also done mine today thanks. It's cheap and certainly worth it.I cut it off. Also did the "bolt" trick to give me an extra 1" of effective length. Very happy now.
