Stark Varg EX range
A subricriber wrote into Motocross Action magazine asking if they 'were against' electric motos as they hadn't tested the Stark.
They had several key points (can't hear them on the track, not allowed in all venues) but their main hangup, understandably was the range. At the end of their response, they said - New longer lasting battery technology is promised in the near future, but we've been hearing that for 10 years.
I thought about that, and for the most part, thats true. The Alta had nearly the same range 10 years ago as my new EX.
For the record, I'm just over 200 lbs without gear, I ride pretty hard core single track, and I'm getting 35+ miles out of a charge. 40+ on easier rides. I was hoping for more as many of my rides can go 45 or more.
2018 Alta battery 5.8 kWh
2022 Stark Varg prototype 6.0 kWh
2023 Starg Varg production bike 6.5 kWh
2025 Starg Varg EX 7.2 kWh
All that for 32 kg battery packs.
So from the latest Alta to the latest Stark that's 24% increased energy density in 7 years, or from Stark 2022 prototype to the EX that's 20% increased energy density in 3 years.
In fact it has nothing to do with motorcycle manufacturers, it's all down to cell suppliers and continuous improvement in 21700 commercial cells. For instance take Molicel, their P42A was released in 2020, P45B in 2023 and P50B in 2024. That's 4 years to go from 4.2 to 5.0 Ah, 19% increase in energy density.
New leap in capacity has been 10 years away for a while, hybrid are close to production, solid state batteries still aren't. But steady improvement with proven tech gives about 20% gain every 4-5 years so following that trend you can reasonably expect about 50% gain in 10 years. That'd be 10 kWh 30 kg batteries without any revolutionary tech.
Yeah I know Stark is not using Molicel for the EX, it's just concrete example of capacity increase from a leading cell manufacturer.
I've been thinking about this lately. I think for a large share of the off road market to even consider an electric bike as their primary ride we need a 2X improvement in range. For mass adoption, need 4X. It's an awesome toy right now for those us fortunate to be able to afford two bikes. A 4X improvement in range and/or charging availability, it's game over for ICE, these things are too good in all other areas.
I am
I am not sure about 2X vs 4X my guess is possibly 2X would be sufficient for mass.
The problem right now is battery tech still needs some serious catch up. Wet batteries are 19th Century tech. A real solid state solution with weight savings and improved range/fast-charging alone might be enough of a game changer.
Many of today's features on Stark first gen make it a better choice than my ICE bikes (KTM 300 2T and WR450F).
My EX did 45 miles (over 5.5 hours) of challenging single track, and a good bit of fire roads (to connect the singles..) I returned to the van w/ 15%, but had a good chunk of the miles back to the van downhill (of course, I had to go up initially). What I'm seeing is that speed is what kills the battery... even if I keep the fire roads less than 25mph it chews up battery (esp if it's up a steep hill). Singletrack is where the battery shines, esp if it's more technical in nature (less speed).. I'm convinced if it was a decently challenging trail, and no fire roads, I could do 60 miles (or close to it).
I'm using power mode 3, which for me is similar to a 300 2T, so 40hp and 10% regen.
Agreed!! on the technical. Stark is awesome in slow gnarl. Hands down the best slow gnarl bike I have ever owned. Even though it is heavier than than the my 300 2T it is way more control-able and the low end is great. And I drop it less. I thought the fly-by-wire no clutch would be problematic in the gnarl, but just the opposite, it is better for me at least.
I think the throttle on the Stark is one of its greatest features and it silently sets the Stark apart from most other bikes I have ridden (E or ICE).
interessting. since he didnt want to tell whats used (telling its molicel would be quality advertisement) i guess they switched to EVE 50PL than.
They were quite happy to show they were using Molicel (and putting Molicel stickers on race bikes), not sure why they keep it secret this time around.
What is your highest sustained speed on your commute?
The biggest problem I have with the EX is the seat - spending 2 hours on that thing is consider a torture device according to Geneva conventions. Still waiting for my aftermarket seat. My commute is only 6-7 miles depending how I go about it, but it is all surface streets, sadly. So far, even with my liberal throttle use, I'm seeing around 9-10% one way, which works out to 60-70 miles, but if I can ever dial down the power and cruise at reasonable speeds, it might increase the range a bit
Una económica pero buena solución es usar pantalones de bicicleta que incluyen un cojín cosido justo ahí!!!
Lo probé hoy en un paseo hard enduro de 2, 5 horas y 50 kms y fue bueno
My butt is starting to get used to it. I went through the same thing when I first got my DRZ - after a couple months of raw butt cheeks, you eventually build up callouses. I have been riding 3 hours straight for two days on the weekends, and it doesn't really bother me anymore. I wouldn't want to do a cross country ride on the the thing, of course, but thankfully that will never happen on this bike.
Commuter range test
60 miles from 100% to 10%, 15 hp, high regen, 35 mph, no highway, constant speed.
This is a high estimate, more agressive riding, more challenging route or higher speeds will decrease range.
I've found the same, on my lighter emoto (erpss 2.0) swapping the seat ended up being a requirement after a while because more than 30-45mins was unsustainable. On the Stark I've pretty much gotten used to it and don't really notice any discomfort unless I'm really out for a long time.
Loving my custom seat by Seat Concepts, much better than the EX brick I was enduring
Probably 70mph in a stretch or two.
Do yourself a favor and order a Guts seat, looks just like the factory seat but it's much softer. The material is really harsh though, you'll not want to ride it without pants.
Dialing down the power won't increase your range, it's all about throttle. Using 30% throttle at 80hp uses the exact same amount of energy as using whatever the scale is at 40hp. I've tried this ad neausium with my electric vehicles, you're using what you're using to attain whatever speed you attain... don't overthink it.
Which Guts seat did you install on your Stark?
Racing my EX last weekend on a hilly course with a 15mph average I was using 30-35% of the battery every 5 mile lap, so about 15 miles total range.
Local trails I get about 30 miles off a full charge.
Slow technical riding I'm getting about 4 hours off a charge.
