Rear axle blocks KTM?? Flag mount
Could be. I need a flag mount for the dunes and there are some overpriced fancy billet aluminum ones that fit a large range of years for all KTM bikes but there were two axle sizes mentioned (comes with an adapter collar for both).
Speedkills
Nederland, CO
Do you happen to know any specific year/model KTM that has that rear axle? It'll make ordering blocks easier as most of the sites tend to want a year and model.
This is what TM Design Works lists as what their KTM axle block flag holder w/20mm axle will fit;
KTM (03-12) 125-530 All Models 2 & 4 Stroke PDS (No Link) models
KTM (13-18) 125-300 XCW 2 strokes & 250-500 XCF, EXC 4 Strokes
Husqvarna (2014) FC 250 & FC 450
Husqvarna (14-15) FC 350 & TC 125
Husqvarna (14-18) FE 250,350,501 & TE 250,300 & TEi 250
Husqvarna (16-18) FE 450
Husqvarna (15-16) FE 350S, 501S & TE 125
Husqvarna (14-16) TC 250
Husqvarna (17-18) TE 150
Husaberg (09-13) All Models
This is the “ModQuad” flag mount for the KTM. It had a bushing so it worked for either 20 or 25mm axles. It’s technically upside down the way I have it mounted but it will work just the same.
So if i'm reading that correctly, the axle blocks from a 14-16 TC 250 will fit? I hate the old style chain adjusters and prefer to use the Bolt brand style. I have them on my KX450 and its so easy to adjust the rear axle/chain tension and the blocks stay in the swingarm when you remove the rear tire.
Bolt Billet Aluminum Chain Adjuster Blocks
According to that list yes. It appears that all KTM’s use the same block with only difference being some use a 25mm axle and some 20mm. That list would be of the 20mm variety.
