What is the correct adapter for a 50 amp RV outlet?
Keep in mind, that is only a 120v charger, so even though it will support 50amp of 120v, you will only get the same charge speed as a home 120v 15amp circuit (1,600watts); not the speed of a 240v (3,200watts). You probably know that already, but mentioning it for other readers.
Still, campground plugs are a handy source of power.
Edit: This comment is incorrect. Was thinking TT-30R vs 14-50R outlets. See further conversation below.
That 14-50 is a 240v 50 amp outlet.
The 3 prong TT-30 camper outlets are 120v 30 amp.
Right you are @AL_V. My head was in the TT-30 space. Duh. TT-30 is 120v and with L14-30 adapter will charge at 120v rate. 14-50R are 240v and the two poles can be split to 120v with an adapter. Or, both legs used to keep 240v (like with a NEMA 14-50P to L14-30R adapter you had linked) to get that sweet, sweet max Varg charge rate.
fe501tired
ca
Assuming you already have a 120v adapter, that will work with any available TT-30 to 5-20 (or TT-30 to 5-15) adapter.
I wanted to go from 120/240 30 amp to which I believe is the starks male plug to a 120/30 amp rv plug I am trying to save weight when buying a generator and the big 120/240 are heavy verses the 120 volt 30 amp generators
I did find a plug adapter that goes from the stark plug to a standard household plug
The USA Stark charger uses an L14-30 plug, but they usually supply an adapter to regular household 120v (5-15).
Some of the standard L14-30 to 5-15 adapters won't work, there are threads on this forum you should be able to find.
The reason they don't work is that they connect the L14-30 neutral (which is not used at all in the Stark plug) to the 5-15 neutral.
If you want to go from L14-30 to TT-30 in one adapter, you may have to make it yourself, which would be very easy.
You just have to know that the Stark charger only has 3 wires; ground and L1 and L2 (or X and Y as shown below), on 120v L1 and L2 become hot and neutral (of course ground is ground in all cases).
fe501tired
ca
View attachment 15344View attachment 15345View attachment 15346
Thanks for the help I will either get the big generator or just get the small one that only uses the household plug but take twice as long which is fine I only play ride 30 minutes here then hang out camping with the kids and grandkids then 2 hours later maybe a 30 minute ride .
For charging your Stark, there is no advantage to the TT-30 over a regular 120v 5-15 (household plug).
The big generator should already have an L14-30 (240v), which would be twice as fast as 120v, just get at least a 4,000 watt generator for 240v, or 2,000 watt for 120v
leadingedge
I highly recommend the WEN 6800 compact generator. I have one and it charges my Stark at full speed & 240v if I want to.
It has a L14-30 port that you can plug your Stark charger into without any adapters.
Link below for you:
fe501tired
ca
Link below for you:
It's funny you mentioned the Wen 6800 that is the one that I have in my cart on amazon along with the wen 4800 and 3600 my only problem with the wen 6800 is the weight I need to be able to pick up myself and I hear it weighs about 100lbs which I know I could do it but damm.
leadingedge
It's a little hefty, but I can load mine myself. It has a retractable handle and wheels which may help if you pull it up a ramp or something - if needed. But it's a great generator. Very compact for its output.
