JARV-E (enduro)
Legendary enduro rider Graham Jarvis is putting his name to a project of electric Enduro bike.
Lighter than a Varg, hot swappable batteries (although obviously smaller), app controlled from your own phone is what a lot of Enduro riders have been asking for, so it could be interesting.
The bike is light but so are the details about this project, with a production start scheduled in about 4 months...
50 kW (68 hp)
95 kg
5.6 kWh
That makes it an intriguing prospect if it's specced more like a Varg than a Surron to handle rough terrain, and if the price is right (no information about that).
Sirris suspensions, like the Dust, e clutch, and likely made in Austria
Founder has been developing e-bikes for a while and finished Romaniacs emoto expert category last year on supposedly one of his prototypes
Some additional information from the website, some of which is got hovering the mouse cursor on the + signs on the picture:
• Sirris F43 suspension; interestingly, it seems to be a dual chamber fork with Ø43 mm stenchions but the F43 writing pops up hovering the cursor over the rear shock
• rear shock without linkages and a visible tilt that I presume achieves progression instead
• 21"-18" wheels
• e-clutch
• CNC milled swingarm and triple clamps; in other topics we got to the conclusion that those propotypes have machined triple clamps probably because casting would be more expensive for small batches, but apparently this is marketed as a permanent feature
• 3.4 kW charging
• Jarvis is not only going to sign the bikes, he is part of their team: "He leads riding development, testing, race strategy and the long-term vision for JARV-E." He has also developed a riding mode available for the customers.
• The battery capacity after 500 charging cycles is expected to be 80%.
• two years warranty
I like that the prototype is being raced in important competitions before they even produce the bikes. Racing is the real test people want to see.
They are also hiring to expand the company.
Good eye!
I like that they already foresee to make replacement packs available.
The path from prototype to production is hard, they appear to be at very early stage without any release date nor price.
So, not a motocrosser with that frame design, I do like some of their setup choices though: Chain primary rather than enclosed gears, simpler, lighter though slightly more power loss. Main shaft is also the swingarm pivot so constant chain slack at all times. IIRC this impacts anti-squat though, not sure it's really a concern at hard enduro pace vs say, road racing where I normally play? Front sprocket changes are going to require major disassembly. Looking at long term strength, that steering stem area is spindly, and the swingarm pivot is behind the main rear downtube with not much visible bracing / triangulation? Again, not a MX/SX targeted machine.
EDIT: Looking closer at the swingarm pivot area, I just realized, the pivot point is adjustable. The silver side plates that also hold the pegs are the entire pivot point structure, it's not supported by the frame at all. The forward mount point for those plates has two holes, by changing which one you use you can move the swingarm pivot point up or down. This alters the shock progressiveness and swingarm angle. It also moves the pegs relative to the seat/frame a bit too so, interesting... The mount bolts for those plates are blocked by the primary sprocket so can't go all the way across for strength on the rear bolt, front bolt looks to possibly be able to be a single bolt across the frame with a gusset tube between for strength?
SIRRIS suspension scores again, the rear geometry worries me though... I'm used to PDS / linkless setups, this is setup to be VERY progressive, and eyeball math has me worried that a hard hit could push it 'over center' depending on how hard the stop is on that shock? I'd like to get the actual numbers on it to run the math.
That said, I do like finally seeing a full size machine that appears to actually benefit from going on an electric diet. This has my attention as likely a closer match to my actual ability set these days, and much lighter, this is closer to my two strokes that I love weight wise. I do hope they come out with alternate rear side plates with more number plate area AND mud flap function.
I haven't found pictures of the bike from the right side, but yes, from the left it looks like that. Some BMW designed Husqvarnas like the TE 449 used this solution, that they called CTS: Coaxial Traction System. Here is an interview about it to an Italian professor from back then; the subtitles seem right except for when he mentions landign from a jump doing cross country: it's motocross, not XC:
The advantage of less slack in the chain + the instantaneous torque of the electric powertrain must make that one of the most reactive motorcycles ever made.
Well, I've found out that for that fork, for example, there are spare parts available like this rebuild kit and tutorials like this about how to change the spring. I don't expect to find as much spare parts and information as with older, more common manufacturers, but I also guess that they would be cooperative if asked technical questions.
When you say "over center", do you mean like this? It doesn't look like it can compress so much.
That's exactly what I meant, either going digressive or absolute worst case scenario, the shock starts forcing the swingarm UP. Ran into that with some Chinese pitbikes back in the day, they relied on a rubber soft stop to keep things in check. Hammer a jump as an adult on said bike and suddenly your swingarm was stuck beyond fully compressed. (And if you had adjusted the chain as per the stickers, likely either snapped the chain or bent the output shaft...) I have to assume they're aware of and designed to not allow that to happen, but it was my first thought looking at the layout.
Is Jarvis allowed to do this with his Husqvarna contract? Or has that ended?
Also that's a very tiny battery for it's capacity. Wishfull thinking or some fast advancing tech?
This has business of being on a MX track for sure. But i can see this being a weapon in places like Erzberg, Pascuet, Bilstain etc. This will crawl extreme stuff like nothing else.
I signed up, but have not made a deposit.
I asked via email for the wheelbase and seat height, which I could find anywhere.
Hello Allen ,
thank you for signing up for the JARV-E Graham Jarvis Signature Pre-Order.
We are currently finalising the first limited production run of 100 numbered Signature Bikes, available exclusively through pre-order.
Bike & Pricing​
  • Net price: €12,200(approx. USD 13,200 – indicative only, based on current exchange rates)
  • VAT is not includedand will be added with the final invoice, according to the applicable tax regulations at delivery.
  • All payments are processed in EUR. USD values are provided for reference only.
Reservation, Deposit & Allocation​
To secure a valid and confirmed production slot, a deposit of €3,500 (net, excl. VAT)(approx. USD 3,800 – indicative) is required.
Production slots for the first batch are allocated strictly in order of confirmed deposits. Availability is limited.
Please note:A reservation becomes valid only after receipt of the deposit.Until payment is received, no production slot or bike number is assigned. Unpaid slots may be reassigned at any time.
The deposit:
  • secures one of the numbered Graham Jarvis Signature Bikes (No. 1–100)
  • reserves your bike in the first production batch
  • is fully credited toward the final purchase price
  • is fully refundable at any timeuntil final purchase confirmation
  • initiates final specification and delivery planning
Delivery Schedule​
Current planning foresees first customer deliveries starting in March 2026.
USA & Overseas Shipping​
Due to the high level of international demand, we will organise consolidated shipments with a structured allocation between USA and overseas destinations from the start.
Further details regarding shipping method, routing and customs handling will be communicated at a later stage, once production planning is finalised.
Please note: Shipping costs for USA and overseas deliveries will not exceed standard European delivery costs.
Payment Details​
Once the deposit is received, your production slot is automatically confirmed.
Amount: €3,500 (net, excl. VAT)
Next Steps​
After receipt of your deposit:
  1. You will receive a formal confirmationof your secured production slot.
  2. Your bike will be assigned a unique frame and bike number (No. 1–100), allocated strictly according to payment order.
  3. Your individual delivery timeframewill be scheduled based on your assigned bike number.
Great infos, thanks!
EX is under 11k€ before tax so JARV-E would be around 1500 € more expensive.
First deliveries expected in March, that's... really close! Maybe they have stashed a factory somewhere in the Austrian Alps or maybe they'll go with a more modest approach and low production output. Or they're overly optimistic, which would not be a first for an EV company 😆
I hope they can deliver during the first half of the year, they have an interesting approach and it's always good to have more choice.
Those bikes are not available for test rides and only the founder has tested one, as far as we know. Therefore, IMO they should provide potential caustomers with all possible information: wheelbase, seat height, dyno chart, weight distribution, brake rotors diameters and so on. Personally, I wouldn't spend that kind of money on a bike I know so little about.
They should provide potential customers with a lot for the huge a deposit. I think I would take a chance on the 100.00 on the Verge to 3800.00 on the Jarvis... I would be very careful laying out that kind of money for a promise of production. We all know how that can go.
💯 agree. $100.00 US ok maybe worth the risk. Almost $4k US you better show me pictures of my bike on the production line and when it is loaded on the skid and at the dock ready for ship. We all saw what has happened in the past. Promises made promises not kept.
Once the product arrives at U.S. Customs, I believe the customer is responsible for paying an additional 15% (or more) import fee (Customs duty plus broker fee). The sellers will not usually tell their customers this information and we don't find that out until we're already on the hook for the full amount.
The deposit is refundable (unless of course they become insolvent, but how could that ever happen?).
Here is some more info (.pdf attached)
JARV-E
Factory Technical Specifications
Chassis & Structure
• Modular high-performance hard-enduro chassis platform
• Precision-welded 25CrMo4 Chromoly steel main Frame
• Multi-section architecture for serviceability and modular Upgrades
• Industrial Powder-corrosion-protection, high-durability finish
CNC Swingarm
• Fully CNC-machined modular aluminum swingarm
• Hard-anodized surface treatment
• Optimized torsional stiffness with controlled flex
• Designed for extreme electric torque loads
Fasteners & Axles
• Complete chassis equipped with aerospace-grade titanium fasteners
• Titanium axles (front, rear, chassis interfaces)
• Reduced weight, high fatigue strength, corrosion-free
Suspension — Factory Setup
Front
• Sirris F43 closed-cartridge enduro fork
• Extreme hard-enduro specific valving
• Front wheel travel: 260 mm
Rear
• Sirris R46 JARV-E Factory Shock
• Race-specific traction and bottom-out control
• Rear wheel travel: 265 mm
Powertrain
Motor
• High-torque permanent-magnet electric motor
• Optimized for low-speed control and high-load technical riding
• Designed for sustained torque delivery in extreme enduro conditions
Performance Output
• Peak power (hardware capability): up to 50 kW
• Continuous power: 25KW Endurance-optimized for long hard-enduro stages
• Torque characteristic: Instant torque from zero RPM
• Multiple ride modes with adjustable throttle response , torque curves, clutch and Regen
brake modes
Battery System
• Battery capacity: 5.6 kWh high-energy lithium pack
• Voltage architecture: High-voltage 87V performance system
• Cell type: Premium high-power 21700 cells
• BMS: Intelligent battery management system
o Cell balancing
o Overcurrent / overtemperature protection
o Voltage and thermal monitoring
o Active communication with controller
• Design focus:
o Mass centralization
o Impact and vibration resistance
o Service-friendly race access
Geometry & Dimensions
• Wheelbase: 1415 mm
• Ground clearance: 350 mm
• Seat height: 940 mm (medium-height seat)
• Full-size ergonomics optimized for perfect standing control
Weight (Race-Ready Configuration)
• 95 kg ride-ready
• Including:
o 5.6 kWh battery
o Race-ready tire setup
For anyone considering a Jarv-e please proceed with caution as based on my experience in working with David who is the designer and listed on the Jarv-e website. It has not been a good experience.
The Jarv-e is based on a bike previously called Eduro. In April 2024, paid in full for a Eduro frame kit with suspension and wheels to David of Eduro. Since payment have not gotten anything - no Eduro frame kit or no refund. Been pursuing a refund from David for the last year but at this point do not want a Eduro or Jarv-e.
If you considering a Jarv-e think about support, warranties, and parts replacement availability. Also do not pay any funds until you can physically pick up your Jarv-e/Eduro. Sharing for awareness as do not wish to see anyone get burned.
Great advice..if the company won't accept a deposit thru PayPal or a credit card (where they have very little exposure if you cancel - they can sell it to the next buyer) than you should pass. If they require a bank transfer you have zero recourse...especially if it's International. I once paid in full for a bike that never materialized. Fortunately, I used a CC & the owner of the company was a gentlemen & refunded my payment immediately...if he wasn't I'd still be trying to get my money back.
The saddest part is scammers will crush this industry. All it takes are a few horror stories & the legitimate guys will be swept away with the trash & we all lose.
