Fast 7kW charger
A charger, for a dirt bike, that can't be exposed to dust or humidity...
Nice to see a faster 110v charge option for the US though, but we're still locked to 3.5kw max unless you're in a place with industrial power.
Well that manual shows a Nema 14-50 plug, and someone said it doesn't really use 3 phases, so it should be fairly easy to use in the US.
My generator has a 14-50 outlet.
That's two 110v phases though, if the charger only operates on single phase, you're capped at the 110v limit of 3.5kw.
if you plug it to 110v outlet max will be 240v, but if you plug it 240v in US (split phase) I think this will work, inside is probably 20A charging module as in other external DC CCS chargers - they will not make it custom bcoz not a lot ppl will buy it - they make custom mobile and probably not even make profit on them - even if this is very low margin
