Well that manual shows a Nema 14-50 plug, and someone said it doesn't really use 3 phases, so it should be fairly easy to use in the US.A charger, for a dirt bike, that can't be exposed to dust or humidity...
Nice to see a faster 110v charge option for the US though, but we're still locked to 3.5kw max unless you're in a place with industrial power.
That's two 110v phases though, if the charger only operates on single phase, you're capped at the 110v limit of 3.5kw.Well that manual shows a Nema 14-50 plug, and someone said it doesn't really use 3 phases, so it should be fairly easy to use in the US.
My generator has a 14-50 outlet.
if you plug it to 110v outlet max will be 240v, but if you plug it 240v in US (split phase) I think this will work, inside is probably 20A charging module as in other external DC CCS chargers - they will not make it custom bcoz not a lot ppl will buy it - they make custom mobile and probably not even make profit on them - even if this is very low marginThat's two 110v phases though, if the charger only operates on single phase, you're capped at the 110v limit of 3.5kw.
It's a 14-50 not a 14-30In Europe the three phase plug will have 3 phases, neutral, and earth/ground. Phase to phase voltage is 400VAC, and each phase to neutral is ~230VAC. Since the stated draw is 32A max, that max 32*230=7.4kW
So in the USA, a nema 14-30 (commonly used for electric clothes dryers) is rated for 30A at 240V. So if you plug it into that, you should be able to get 7kW out of it.
