happyinmotion
- New Zealand
The control switch on my MX 1.0 has been misbehaving - the status LED is always dimly light and the bike occasionally behaves as if the buttons are held down.
Sounds like dirt in the switch, yes? But taking that apart and cleaning it thoroughly didn't help.
So next steps is the connector, where a found this issue. The sealing ring is swollen and buldges out. It isn't sealing or keeping dirt out. I think contamination here is causing leakage between the wires leading to my control switch problems, or the sealing ring is pressing on the pins. Current is tracking through dirt on the ring and making weak shorts between the pins. But the seal won't even sit back into the right place so the connector can be connected.
Anyone else had this issue? Is there a resolution other than just running without the sealing ring?
(And yes, I have raised a support ticket with Stark on this but no response yet.)
