rtf
- Orlando, FL
Can anyone shed some light on some optional graphic kits for the MXR? While I don't mind the stock plastic on the MXR, I've seen some others that I prefer much more. Anywhere to buy any others?
Welcome to the Forum, rtf!Can anyone shed some light on some optional graphic kits for the MXR? While I don't mind the stock plastic on the MXR, I've seen some others that I prefer much more. Anywhere to buy any others?
The way it is going, we may have to create a special Decals and Graphics Kit category. For now use the Search function (the one with a magnifying glass icon):
https://altaownersforum.com/search/18/?q=Decal+graphics
Yes, they are the same. I just compared the shaped and the mounting points on my two bikes, and they are identical.Another random question, does anyone know if the MX plastics will fit on the MXR?
Also, Alta would not invest in new injection molds without a good reason, and AFAIK there has not been such a reason yet.
I thought the rear subsection was modified to raise the rear fender so the new shock/link wouldn't bottom on it? It definitely looks higher than my 2017, but the swingarm angle could have changed as well.Yes, they are the same. I just compared the shaped and the mounting points on my two bikes, and they are identical.
Not sure about the rear subsection, but the fender appears the same. I have heard that the rear wheel's travel was slightly reduced instead.I thought the rear subsection was modified to raise the rear fender so the new shock/link wouldn't bottom on it? It definitely looks higher than my 2017, but the swingarm angle could have changed as well.
