A friend broke her EX's display. Anyone have any idea where a new one (generic perhaps?) Can be found.
Will a descent electrician be able to fix such display, or we shouldn't even try?
Does the back light even turn on?
And to think there is a pile of new displays just waiting behind the closed doors of the Alta facility.
And here we are trying to improvise a resuscitation to a dead display.
It would depend on how beefy it was. If an aluminum housing was made as thin as I suspect the plastic one is, it would probably be damaged just as easy.That damage looks like an aluminum housing would have prevented cracking the screen.
There is not. Displays are one of the items of which we had no inventory. So, even if Alta was still in business, you would have no parts. Engineering had spec'd a new display, but that was not delivered before the doors were closed.
Do you think we can replace the LCD display while leaving the display drivers alone to avoid the firmware issue or is it one integrated module?The display is the termination point of the CAN bus. Unless you are able to install firmware on it, it will not communicate with the rest of the bus.
@Oded, does the bike still work? I thoght I read somewhere that without the display the bike wouldn't work.
