WoodsWeapon
- USA
I dont know if it helps or means anything, but when datadog replaced the battery on my MX, the hours reset to zero on the display, but the mileage stayed the same.
If you jus mean disconing the wire behind the number plate, you will be fine. I'm trying to think of a spot to relocate my dash where it will be more out of harms way as well, but the trick seems to be making it at least relatively easy to still see.@datadog Can the display be disconnected and reconnected without any reprogramming? (Same bike)
I’am thinking of moving it to a safer location.
I’am thinking under the seat behind the shock. I don’t look at it when out riding. To old and slow to check it with my eyes. Only check it when chargeing.If you jus mean disconing the wire behind the number plate, you will be fine. I'm trying to think of a spot to relocate my dash where it will be more out of harms way as well, but the trick seems to be making it at least relatively easy to still see.
I've thought of that area too. The thing that stops me there is I don't like the options for mounting points. I am thinking about taking the board out and maybe making a new box for it, but I'm not into opening my dash without a readily available replacement.I’am thinking under the seat behind the shock. I don’t look at it when out riding. To old and slow to check it with my eyes. Only check it when chargeing.
Yes. And also the green light aroundDoes the back light even turn on?
It works. And so does the display backlight. It's just crackedDo you think we can replace the LCD display while leaving the display drivers alone to avoid the firmware issue or is it one integrated module?
@Oded, does the bike still work? I thoght I read somewhere that without the display the bike wouldn't work.
Looks like these two guys with such displays have tried this already.If we can non destructively remove the display from the PCB we can see if there are part numbers and determine if it is a commercially available part. If the display is available, then replacing it doesn't seem that difficult if you have the right equipment/tools.
The LCD itself is cracked. I did take it apart and it has Alta printed all over the board so there’s nothing generic about it or any clue of who may have made it for Alta.
Can anyone recognize that pyramid-looking "SC" logo?https://photos.app.goo.gl/tjiN7Xn1TR365GRw6
https://photos.app.goo.gl/9GQ1o8FVkDzNQDbi6
lmk, if there is something specific you want closer shot of
