- Charlotte, NC
Here's the stock midvalve stacks for the MXR WP Shock with Alta's updated settings.
All shims are 12mm ID and the first shim is the piston facing shim.
Compression Stack:
Compression Stack:
- 45mm x 0.25
- 44mm x 0.25
- 42mm x 0.25
- 40mm x 0.25
- 38mm x 0.25
- 36mm x 0.25
- 32mm x 0.20
- 30mm x 0.20
- 28mm x 0.20
- 26mm x 0.20
- 24mm x 0.20
- 22mm x 0.20
- (5) 30mm x 0.30
- (3) 40mm x 0.25
- 38mm x 0.30
- 36mm x 0.30
- 34mm x 0.30
- 32mm x 0.30
- 30mm x 0.30
- 28mm x 0.30
- 26mm x 0.30
- (8) 24mm x 0.30
- (THICK BASE PLATE)
