MXR Updated Stock Shock Valving
Here's the stock midvalve stacks for the MXR WP Shock with Alta's updated settings.
All shims are 12mm ID and the first shim is the piston facing shim.
Compression Stack:
  • 45mm x 0.25
  • 44mm x 0.25
  • 42mm x 0.25
  • 40mm x 0.25
  • 38mm x 0.25
  • 36mm x 0.25
  • 32mm x 0.20
  • 30mm x 0.20
  • 28mm x 0.20
  • 26mm x 0.20
  • 24mm x 0.20
  • 22mm x 0.20
  • (5) 30mm x 0.30
Rebound Stack
  • (3) 40mm x 0.25
  • 38mm x 0.30
  • 36mm x 0.30
  • 34mm x 0.30
  • 32mm x 0.30
  • 30mm x 0.30
  • 28mm x 0.30
  • 26mm x 0.30
  • (8) 24mm x 0.30
  • (THICK BASE PLATE)
